It is currently Sat Nov 07, 2026 11:49 am
PostPosted: Wed Oct 22, 2014 9:29 am
I want to choose the custom Start button option but I'm not sure what size I would need.
PostPosted: Wed Oct 22, 2014 2:09 pm
Its not too hard to change, if you think its too big/small
Though anywhere from 40 to 65 seem appropriate for most buttons
Unless you are asking what size the image should be? I would recommend somewhere between 48x144, and 300x900 for most buttons.
Just remember the image is split evenly(vertically) into 3 different 'states' (pressed, unpressed, and hover)
