It is currently Sun Nov 15, 2026 12:19 am
PostPosted: Fri Jul 26, 2013 8:34 am
Is there any way to make it so a pinned item cannot appear in the recents menu? If not, it should be added as a feature.....for example I use the Windows Calculator enough that it typically appears in my recent list, but on Win7 I used it enough that I pinned it, which caused it to not appear in the recent programs list.
Is that available in Classic Shell or should I make a feature request?
Beyond that, loving the customization that ClassicShell adds.
PostPosted: Fri Jul 26, 2013 8:41 am
That's how it works in the new version 3.9.0.
PostPosted: Fri Jul 26, 2013 8:43 am
Ok, I'm on the stable release (3.6.8), while I don't mind jumping to beta versions it's something minor enough that I'll for 3.9 to go stable. Any estimates on when 3.9 will go stable?
Thanks.
PostPosted: Fri Jul 26, 2013 8:46 am
No.
PostPosted: Fri Jul 26, 2013 8:52 am
Fair enough, it seems 3.6.8 has only been out for a month (roughly)......as a new Win8 user I'm loving ClassicShell, keep up the excellent work.
Users browsing this forum: No registered users and 242 guests
