It is currently Tue Nov 17, 2026 1:48 am
 Post subject: Windows Search question
PostPosted: Tue Jul 22, 2014 1:17 pm
I love Classic Start Menu! I've tried pretty much every one of the "start menu replacers" out there, and it is by far the best. Since you've obviously found a clever solution to a tricky programming issue with Windows Search, maybe you can help me.
My current project has a requirement to call the Windows Search API, and I'm having partial success searching the "God Mode" folder (shell:::{ED7BA470-8E54-465E-825C-99712043E01C}). I get a bunch of hits, but only a subset of the hits that Windows (and Classic Start Menu) gets for the same search term. For example, if I search for the word "allow", I only get:
Block or allow third-party cookies
Change security settings
Set up Family Safety for any user
Allow remote access to your computer
Allow Remote Assistance invitations to be sent from this computer
Classic Start Menu gives me many more hits, in particular:
Allow an app through Windows Firewall
Block or allow pop-ups
I can't even find these "missing" items when, instead of using Windows Search, I directly enumerate the items in the "God Mode" folder.
I've been all over Google, but there isn't much information on this stuff. Can you give me a hint as to what API calls you're using to get the complete list? It would be a huge help.
PostPosted: Tue Jul 22, 2014 9:15 pm
The start menu doesn't use Windows Search to search the god mode folder. It first collects all contents and then does its own string search.
PostPosted: Tue Jul 22, 2014 9:36 pm
Each item in the GodMode folder has a set of keywords associated with it. If you switch to Details view in the GodMode folder and enable the Keywords column, you will see them. Those are also searched.
PostPosted: Wed Jul 23, 2014 8:09 am
Thank you so much for the insight -- this is very helpful.
I fixed the problem of the missing items from my enumeration of the God Mode folder (although I can't explain it).
My test code was running in a console-mode application, and I tried moving it to a windowed application -- lo and behold, there are the missing items! This is extremely weird, but apparently a console-mode program can get different results when it enumerates a shell folder.
PostPosted: Wed Jul 23, 2014 8:13 am
Maybe one was 32-bit and the other 64-bit?
Or maybe you forgot to call CoInitialize, and when running as a windowed app some Windows component calls it for you?
PostPosted: Wed Jul 23, 2014 8:18 am
When either one is 32-bit, I get no results at all. So I know for sure they are both 64-bit.
If CoInitialize wasn't called, I thought I wouldn't be able to call the shell COM objects at all. I was getting results, just not ALL the results.
Anyway, this isn't something we need to figure out. The important thing is that it works! Thanks!
Users browsing this forum: Baidu [Spider], Bing [Bot] and 104 guests
