It is currently Thu Oct 01, 2026 2:48 pm
 Post subject: Multiple displays
PostPosted: Sun Sep 29, 2013 6:52 pm
Hi, I'm a donator, thank you for your work!! I hate Windows 8 not having a task/program bar.
Just wondering if there was a way to duplicate the ClassicShell program bar across my screens.
If I slect "Never Combine" on my main screen, it still show the default "Combined" mode on my secondary device and not what I selected.
This is not true for the actual Menu display, I can choose Classic style and have it look like XP on both displays, it only seems that the actual Program Bar at the bottom doesn't transition across.
Thanks! adam.
PostPosted: Sun Sep 29, 2013 6:57 pm
I am not exactly sure what you are asking. You are talking about "Combine" and "Never Combine", which are settings for the taskbar. However Classic Shell doesn't do anything with the taskbar.
PostPosted: Sun Sep 29, 2013 7:37 pm
Classic Shell does not affect the Taskbar besides adding a Start Menu. When you connect additional monitors on Windows 8, you get extra settings to configure the always combine/never combine behavior for the additional taskbar. They are in Taskbar Properties in the Control Panel.
Users browsing this forum: No registered users and 66 guests
