It is currently Sat Nov 29, 2025 7:31 am
PostPosted: Sat Feb 25, 2017 5:48 pm
(I have the option to display icons in boxes disabled)
All Metro icons have an ugly square behind them.
(Example of what I'm talking about: https://i.imgur.com/XriOGJc.jpg)
How do I get rid of this? StartIsBack doesn't have this and I was wondering if I could get the same thing on Classic Shell
PostPosted: Sat Feb 25, 2017 7:54 pm
The Metro icons are white and will not be visible on a white background. You can try the "Invert Metro icon color" setting in the Menu Look tab.
PostPosted: Sun Feb 26, 2017 3:43 am
In Classic Start Menu Settings,
- Uncheck "Show icon frames" on the Skin tab.
- Check "Invert Metro icon color" on the Menu Look tab.
Users browsing this forum: No registered users and 117 guests
